  • »A.S. Motorsport« ist der Autor dieses Themas
Donnerstag, 29. September 2011, 10:44
ASM BBK Big Bake Kit und Drosselklappengehäuse aufbohren!
Hello Everyone,
I'd like to let everyone know we've update our ASM product line and engineering and fabrication services.
What's new?
Expanded line of Big Brake kits (BBK) and OE BBK's.
5 NSX BBK's
3 NSX OE BBK's
Throttle body rebore service and new thermal TB mounts.
Thermal insulating VIS delete plates. (FI)
Let's get into some more detail on our Big Brake Kit range
We have designed our bake kit with a built in brake bias specifically for the NSX.
This isn't your run of the mill kit.
OEM-BBK
Bigger 2 piece discs with machined caliper spacers for OEM calipers
328x28mm Front €808
322x22mm Rear €1080 (the complete kit will give more front bias)
NA2 Hybrid kit €725 (slightly more front bias)
BBK
Large diameter 2 piece discs with larger calipers mounted on machined adapters,
Front
355x32mm – 6 Piston – €1825
328x28mm – 4 Piston Acura logo – €1233
324x30mm – 4 Piston monoblock – €1065
Rear
322x22mm – 4 Piston – €1415 (hand brake delete)
355x32mm – 4 Piston – €1950 (hand brake delete)
We can build a bespoke setup for you, please e-mail or call.
________________________________
Throttle bodies
Rebore service, €165
We require you to send us your TB.
We also have used NSX throttle bodies in stock for all model years
These can be rebored for you.
Matching thermal TB mount (plastic) €65
Prices are excluding VAT and ex shipping
More info on ASM products and services can be found in this .pdf catalog
http://www.as-motorsport.com/Catalogs/AS…nce%20parts.pdf
Kind regards, Mit besten Grüßen,
Adnan @ A.S. Motorsport
http://www.AS-Motorsport.com
info@AS-Motorsport.com
NSX & Legend Specalist - NSX & Legend Spezialist
Ich bin Holländer, sorry für mein schlechtes Deutsch.
Metabro
